Percolation and evaporation losses
Dear ALL,
We in Chhattisgarh are in the process of designing Sewerage Master Plan by proposing to trap the DWF flowing in nullahs through a weir and diverting it the proposed STP d/s through intercepting sewer which is also proposed to be laid along the river.
The point is ---since all the existing nullahs are unlined , is it correct to presume PERCOLATION LOSSES as 20 % with only 2 % evaporation losses.
Terrain consists mainly of quartz mica schist & quartzite with granite gnesis intruded by granite & dolerite.
Mayor610
RE: Percolation and evaporation losses
you need to conduct percolation tests to determine percolation rates. evaporation is time dependent and is a function of surface area, wind, humidity, air and water temperature. you will need to estimate loss rates on your parameters
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
News
Close Box
Join Eng-Tips® Today!
Join Us             Close
