I added and removed bar sizes and SAFE does not design for design strips or finite elements
4lrdyD
PE
Hi, I have a problem with the design of slabs in SAFE 16.0.1, the problem is the following.
I added U.S. customary reinforcing bar size and deleted the default bar size, and click OK, a message comes out:
"Detailng results are currently available. They will be deleted if the OK command is executed. Do you want to continue?", click Ok
After this SAFE stopped designing the slabs for design strips or finite elements. Why is this happening? Any idea?, thanks for answering...
For some reason the bar set I add has huge areas and diameters, the only solution I found was to manually add the bar sizes with the correct diameters and areas ...
