Homogeneous Charged Compression Ignition (HCCI)
I am trying to put together an engine test facility to run experiments on HCCI.  I have an old Waukasha fuel research engine and I am looking for companies that manufacture dynamometers that I would be able to couple to this engine. I have found out so far that Waukasha no longer services the lower end (crank case) of the engine, so I may be interested in a complete test set up. The HCCI combustion method basically takes a lean fuel mixture and compresses it until it auto ignites. This condition generally is the knock zone that is why I am using an old octane rating engine. If anyone could give me any companies, information, or suggestions, I would greatly appreciate it.
Thank you,
Ross A. Watters
Raw25@drexel.edu
Ross A. Watters
ross_a_watters@hotmail.com
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
eBook - Rethink Your PLM
A lot has changed since the 90s. You don't surf the Web using dial-up anymore, so why are you still using a legacy PLM solution that's blocking your ability to innovate? To develop and launch products today, you need a flexible, cloud-based PLM, not a solution that's stuck in the past. Download Now
White Paper - Using Virtualization for IVI and AUTOSAR Consolidation on an ECU
Current approaches used to tackle the complexities of a vehicle’s electrical and electronics (E/E) architecture are both cost prohibitive and lacking in performance. Utilizing virtualization in automotive software architecture provides a better approach. This can be achieved by encapsulating different heterogeneous automotive platforms inside virtual machines running on the same hardware. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
