Contact US
Stop Log Swell
Stop Log Swell
Stop Log Swell
I am designing a new flash board structure for a dam which will consist of a metal frame and wooden stop logs.  The stop logs will be 5-inches thick and will be Southern Yellow Pine, Construction grade.
How much should I expect the wood to swell once they are submerged for a long period of time?  Is there a coeficient I can use for different thickness?  I need this information so I can properly design the metal frame to accomodate the stop logs so they can also be taken out.  Thanks in advance.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
News
Close Box
Join Eng-Tips® Today!
Join Us             Close
