Your attention to a post
oldestguy
Geotechnical
Jun 6, 2006
5,183
I figure you all might want to examine the photo on Geotech Other site. I managed to freeze the TV shot. Seems like the driller's aim was good between the two rails.
Ihave seen something similar in Lille (France) where a CFA piling rig did a hole for a piezometer which was not programmed initially. The hole was outside the original piling zone. It went through the subway tunnel underneath and a train collided the string. No death but a few people wounded !
These must be some mighty powerful drills!
Big H:
Actually these days with the carbide cutting tools, drilling through concrete for bridge borings is a regular occurrence. At abutments and mainly where piers will go, drilling through slabs or the deck happens all the time. I would bet the driller figgured "Gosh a buried old basement". Maybe he then went on down into the roadbed.
I recall a boring in Milwaukee where the PL was supposed to be 5 feet from a buried city fire alarm system cable. So they stayed more than 5 feet from the usual PL locations. When the DOT crews pulled up an obstruction, it was a large coil of copper wire wound around the bit. Turns out the PL was in the center of the sidewalk, very unusual. Kinda expensive fix that.
Yeah, maybe you are right but really, wouldn't the driller have an inkling? or the engineer logging the boring?
