Sep 3, 2008 #1 K Krantha Guest Can all of the colors in an xref be changed to one color, so that it can easily differentiated from the active drawing.
Sep 11, 2008 Thread starter #2 S support Guest the key phrase is *|* Be sure visretain is set to 1 or they will all change back the next time you open the drawing and be sure all colors in the xref are set to "bylayer" or it won't work.
