SMIAH
- Jan 26, 2009
- 482
Designing a culvert : most software (e.g. HydroCulv, HY-8) gives the Upstream Head Elevation as final result.
Do you calculate the Upstream Water Surface Elevation (susbtracting v^2/2g) and use this water level to see if the conditions are ok (e.g. under the maximum allowable elevation) ?
Or rather use the Upstream Head Elevation ?
