Wrapping text to a multi-contoured surface
  • Thread starter Thread starter jamescadogan
  • Start date Start date
J
jamescadogan
Guest
Good Afternoon,
I am attempting to wrap text onto a skeletal bone - which
by nature is multi-contoured, how do i achieve this? it
seems that the wrap tool can only work with single axis contours
- like that around cylinder.
Any help would be greatly appreciated.
Best
James
IIRC there is a workaround for that. Could help you on that one - contact me via martin.wrann@gmail.com
regards
Also for the forum:
Wrapping does not work for anything else than rotational features.
There are several approaches to solve this, the easiest is:
Creating an offset-surface, using the sketch as a trim tool to trim away the unneccesary parts of the surface and then thicken the remaining surfaces.
Oh, don´t forget: If you want to do this with a TEXT you need to dissolve the sketch text first, otherwise it won´t work.
