DCMV
Petroleum
- Nov 5, 2011
- 35
We are Going to be making some strength welds on a tube to tube sheet joint we have a calculated min weld size of .053" and max weld size of .168". We submitted a wps and PQR to client welding engineer and it was returned as rejected. The client stated that the PQR has a specified min weld size of .085" and max of .168" and the PQR should have the same min weld size as the engineer calculated for the specific tube to tube sheet being welded. I am kinda of confused, my thinking is that the if calculated min weld size is .053 max.168" and the PQR specifies .083 as min it would be accepted because we are above the min cal of .053. I could see if the situation was reversed with min cal at .083 and PQR min of .053 being rejected. Can someone help me understand the tube to tube sheet with strength weld calculated min/max weld size and the WPS/PQR required.
