I currently have a water header over a waste conveyor and I'm looking for ways to reduce water usage. This header is ~600 feet of 3" schedule 80 pipe suspended above the conveyor. Along the 600' length are 3/4" drops (approximately 20 of them) that put water into the conveyor. There are no spray nozzles, just open 3/4" pipe discharging into the conveyor. These drops do have manual valves to allow the flow into the conveyor to be adjusted at each drop. The header is fed from the municipal water supply at ~60 psi. The water is turned on and off via a solenoid valve on a timer that coincides with the conveyor run time (30 minutes on/30 minutes off). The flow rate through the header when valve is opened is ~125 gpm. The water passes through the conveyor and is collected in a series of floor drains and gravity flows to a water treatment plant via three different catch basins.
I would like to install a pump at one of the catch basins and recirculate some of the water back through the header to reduce the amount of municipal water used since we're paying for every gallon that goes through this conveyor. My thought is to use a 35 gpm pump sucking out of one of the catch basins and feeding it back into the beginning of the main header. I would use a flow control valve to maintain the 60 psi in the header using the municipal water supply. My hope is the small recirculating pump would pump as much as it could into the header and the rest would be made up by the municipal water flow via the flow control valve. There would also have to be a float switch in the basin in case it were to pump it dry the re circulation pump would shut off in which the case the header would be fed 100% from the municipal supply, just as it is now. I'm concerned if this is even possible or will the two flows be constantly trying to deadhead one another? There would also have to be a check valve installed in the municipal supply line to prevent any back flow of non potable water. Thanks in advance for your input.
