WindowsError: [Error2] The system cannot find the file specified
T.E.Dada
Hello Abaqus Users,
Please I need help as to how to solve this problem. Everytime I try to submit a job for any of my simulation, an error "WindowsError: [Error2] The system cannot find the file specified" pops up. What could the solution be please.
I have attached a screen shot of the error.
 https://files.engineering.com/getfile.aspx?folder=78e77352-0c78-4884-b4d1-8fb038eb4e01&file=Problem_Screenshot.jpeg
Do these analyses use any special features such as subroutines ? See if you can export the input file and run the calculations from the command line. Also, try running some simple test models.
Thanks for your reply.
The analyses does not use any subroutine.
I also tried simple test models and it is giving the same error.
However, I will try to export the input file and run the calculations from the command line.
It looks like an incorrect installation. Try reinstalling Abaqus(make sure that nothing interrupts this process) and check all messages from the installer.
