Windchill using Protoolkit
  • Thread starter Thread starter sureshy
  • Start date Start date
S
sureshy
Guest
Anyone please suggest me how create workspace into Windchill or PDMlink using Protoolkit.
And also registering the server, how to get server alias.
and API's for the same
Edited by: sureshy
Read the API Wizard under User's Guide->Data Management: Windchill and Pro/INTRALINK Operations.
Thanks for the valuable suggetions,
i can create workspace using api ProServerWorkspaceCereate
But once i create the workspace its not getting activate,How can i activate the newly created workspace som that i can check out thefile to it
I encountered the same problem. I can set the workspace active in my code and it runs fine (while debugging i can see that the active workspace has changed in my server properties), but when really checking in ProE it still says (inactive workspace)workspacename and the old one is still the primary active one.
did you found a solution sureshy?
The documentation of the function ProServerWorkspaceSet (at least in WF4) says, that it is only supported in batch mode.
