wikidcool
- Jun 20, 2007
- 50
For ASCE 7-10 26.7.3, Exposure Categories for buildings under 30 ft says B applies when surface roughness B "prevails upwind for a distance greater than 1500 ft".
If you have a site that has a quadrant that's fairly open inside that 1500 ft radius with fields, parking, etc, but if you look at it on larger radius like 5,000 ft and the region is B overall - would you consider that B or C? Obviously, the conservative answer is to use C but what is most accurate for how the wind actually would behave on the building?
