Why starting up Catia takes long
  • Thread starter Thread starter Mans
  • Start date Start date
M
Mans
Guest
Why Catia starting up takes long
When I turn on my computer and then click on the Catia icon; from the time of clicking, up to appearing Catia on the screen takes long about 3 to 5 minutes. But when I shut down Catia and open it again, without restarting my computer it appears sooner (about 1 minute).
Is there any solution that Catia is started up in a shorter time, after turning on my computer in the beginning.
This is my system properties
Hi
"Too slow for workbench switches and functions" to investigate such trouble you can do:
Usually I try the following illustration
1. Open your Typical Katia data (this allows you to reproduce the problem)
2. File / send To / Local Folder
=> duplicate the Data on the "Local Folder"
3. Open the "Local Folder" data with CATENV dassault default installation.
CATIA / Tools / Options / General / Document is very sensitive to resolve File Search with "OtherFolder"
Once it get a trouble Load CATProduct : OK , edit CATPart => wait 20 seconds
