Why I can not see the revolve axis?
  • Thread starter Thread starter zhappybird
  • Start date Start date
Z
zhappybird
Guest
Hi There,
I would like to do a simple revolve, I choose revolve tool-create a simple geometry such as a rectangular schetch, create a centerline. then when Iclick the done button and exit the scheth enviorment, I can not see any axis to choose for revolve, any one can tell me the reason?
Thanks.
Mike\
which pro-e version are you talkin about?
there is a slight change in wf5.0 as normal center lines do not work for a revolve command u have to use geometric centre lines
From the dash board, outside sketcher, you can pick a revolve axis from axes that already exist in your model. If you sketch an axis in your sketch, PrO|E will use that one instead.
Then again, re-thinking your question, is it possible that you simply don't have axes displayed? Click the 'show axes' button on the toolbar.
In your sketch, the centerline can be used as your axis. Just right-click the centerline, and choose 'Axis of Revolution'. When you exit sketcher, your revolve will be about your internal (sketched) axis.
Check out the first dimensioning tip. Might help with your revolves.
Edited by: neuronex
