Ok now i understand, have a look at the attached file this is the explanation of the user profile and print group.
From what i understand of it the profile is stored in the user home directory. But in my case we don't use this because our sysadmin has created the files on the server.
Windows:
! GROUP_DIR C:\My Printers
! JOBS_DIR ${UGII_TMP_DIR}\bps\My Printers
! HOME_DIR ${HOME}\bps\My Printers
! LABEL My Printers
! 3. The third line specifies keyword HOME_DIR followed by the path of
! the "home" directory that stores user profiles for this printer group.
! Because user-specific files are created in this directory, you will
! probably prefer to create this directory under the user's home
! directory. The NX Print dialog creates node-specific files under
! this directory.
But I found the other user specific files in this folder :
C:\Documents and Settings\"your windows login name"\Local Settings\Application Data\Unigraphics Solutions\NX75
You need to set the 'Show hidden files and directories' in your folder options in windows.
But maybe John can explain a little more.
Best regards,
Michaël.
NX7.5.4.4 + TC Unified 8.3
