When open STP directly what is the template that NX use? 1
RubenSilva
PT
Hello
When i create a new Model, NX load the template: "model-plain-1-mm-template.prt" and if i import one ".stp" NX keep that template
But when i open one ".stp" file directly, without open a new model, NX dont load that template, but i dont know what template it loads.
Can someone tell me what is the template that NX load in this situation?
Ruben Silva
NX 1973
In the NX install directory you will find folders named STEP203UG and STEP214UG, these hold your settings files and the null part files that NX uses when you "open" a STEP file.
www.nxjournaling.com
You can set your desired settings in a new partfile, then save that in the directory that Cowski described and name it exactly as the existing files. ( rename the existing ones.)
then you get your setup in the imports.
Tomas
The more you know about a subject, the more you know how little you know about that subject.
