C
caddaddy
Guest
Okay
So when you measure something in Creo 2.0 (build M040 and up <im using M090>) why would it take 10 to 20 seconds for the results to pop-up? I've tweaked the measure_sig_figures config and didn't really make a difference, and notice that if I have a top lever assembly open in the background, open sub-assemblies up that I'm working on, make a measurement in on of those sub-assemblies and while the measure tool is still open, look at the upper lever assemblies, they all have the measure created in them as well!!! That's probably not helping the initial regen time. When a single or smaller assembly is open, it's not as bad.
Has anyone had similar issues or found a fix for this?
Thank you
Pete
Thank you
Pete
