what is the difference between subdivision surface and Nurbs?
  • Thread starter Thread starter wowpilot
  • Start date Start date
W
wowpilot
Guest
I wonder which technis is used in catia GSD? and which one is easy? What is the cons and pros of 2 approach to design world?
I had to look this one up, so here's my quick summary:
Both are used to define curves and surfaces. I know that CATIA V5 uses NURBS for GSD geometry, but I'm not sure if other workbenches use Subdivision surfaces. "Subdivison" is a method of approximating a curve or surface. NURBS is a type of equation used to define a curve or surface.
