what is alternative way to get surface nodes? 1
roudan
Geotechnical
Hi
I used to use getBoundingBox() to get surface nodes if outside surface is flat. Now if the surface is not flat, what alternative functions I can use to select nodes on the outside surface?? Thanks a lot
bottom_face=modelInstane.nodes.getByBoundingBox(xMin=X_tolernce*-1,xMax=Model_Width_I+X_tolernce,
yMin=Y_tolernce*-1,yMax=Model_Width_J+Y_tolernce,zMin=ZBot_Under-Z_tolernce,zMax=ZBot_Under+Z_tolernce)
To get nodes only from the outer surface you can create a for loop with if conditional statement inside. Define this statement in such a way that only faces with one associated element are considered (since they belong to the outer surface) and nodes from these faces are obtained.
You can use the part faces to define your set:
[pre]part = mdb.models['Model-1'].parts['Part-1']
set = part.Set(name='Outside', faces=part.faces)[/pre]
Thank you so much oldNail. If I have multiple faces( left, right, top and bottom) and I only want to pick bottom face. How to pick that bottom face? I am thinking I can do part.faces[0] or part.faces[1] or part.faces[3]. The question which one to pick? do you have another trick? Thanks
The part.faces is a FaceArray object. I'm sure you can find a FaceArray method that will help in the Scripting manual. In the worst-case you can iterate through each face yourself and compare centroids, normals, sizes, etc.
Thank you oldNail.
