EdwardNigma
Aerospace
- Oct 18, 2023
- 22
Hello all,
I work in the aerospace industry as a stress engineer. I recently took a very solid aerospace FEA course as part of a master’s program, and one thing I really appreciated was how the instructor emphasized connecting numerical approximations to real-world behavior. Around the same time, a technical fellow at work recommended a practical FEA book that walks through the process of developing and validating models—which reinforced the same idea.
One thing that stood out to me is just how important it is to set up realistic boundary conditions. A model can easily become too stiff or too soft if you’re not careful, especially when you’re trying to represent how a structure interfaces with its surroundings. This seems like one of the most critical aspects of getting meaningful results.
That leads me to my question: what boundary condition modeling techniques or rules of thumb do you use to make your models more realistic?
For example:
If you have experience creating robust and realistic FEA models, I’d really appreciate hearing about any methods or strategies you’ve developed over time to handle boundary conditions effectively. Thanks in advance.
For example:
- In truss-like structures, using a pin on one end and a roller on the other can allow for lateral movement and prevent over-constraining.
- When modeling plates, allowing for lateral deformation can better capture Poisson’s effect.
- In 3D space, the 3-2-1 rule (restraining three points to prevent rigid body motion) seems like a solid starting approach.
