what are igs, dxf...?
  • Thread starter Thread starter choowang
  • Start date Start date
C
choowang
Guest
I am a beginer user of Pro/e, but I don't know how can I creat igs format file in AutoCAD. I can only save file in dxf format file.
I don't understand the question, you aren't able to create iges file into pro/e?Iges files are useful for surfaces scope, what is the link with autocad you are talking about?if you explain better you question perhaps I can help you!
regards, zalb
I believe what your asking is how to create an iges file using AutoCAD that you can then import into Pro/E......if this is the case, then you should know that the standard version of AutoCAD by itself cannot export or 'save as' files in the iges (.igs) format. Although Autodesk does provide an add-on that will allow you to export files in iges format. A good way to see if your version of AutoCAD has this functionality or not is to simply enter igesout at the command prompt when a drawing is open, if the command does not initialize, then you don't have the added functionality and it will need to be purchased from Autodesk.
create a model in autocad and make it out with igesout commond,then u can import in proe
