WF2 color.map to appearance.dmt
  • Thread starter Thread starter cadrus
  • Start date Start date
C
cadrus
Guest
I am in the process of setting up WF2 configuration files. The color.map file has been replaced with an appearance.dmt file. Anyone know where I can find a predefinedappearance.dmt file that has been loaded up with alarge amountof differentcolors, textures, ect? Any new config.pro files related to this? Is the pro_colormap_path option still vaid?
TIA
When in the Colors and Appearance, choose File / Open and open your existing color.map file. Then choose File / Save to save it as the appearance.dmt. I believe the pro_colormap_path option is still valid. This is how I converted my color.map file when we moved to WF.
-Mark
The pro_colormap_path option still valid, as far as I know you can use
either a colormap or appearance file, I did know what the difference
was but promply forgot. I think there is some stuff on in Pro/Help and
in the Pro/E knowledge base about it. Try 2004-10-15_001201_color.zip (as suggested by Richh) for a load of colours.
Hope this helps,
Sam
