Welded head joint efficiency
Dream91
Chemical
BH
I have one vessel 3.3 meter dia with welded heads and shell.
Client has specified that the vessel is spot radiographed . Also, they specifed the joint efficiency of heads is 1 and shell is 0.85.
What does it means ? Does it means that only A joint in the head will be fully radiographed ?
Also, when it comes to calculate thickness of the heads and MAWP of heads , joint efficiency of 1 to be used?
Is the vessel R4 stamped?
Is this a Sec VIII-1 application?
If so and you have a copy of ASME Sec VIII-1, review Non Mandatory APP L. In particular look at Fig L-1.4-2.
If other specify.
