zzefer
- Nov 3, 2012
- 1
Hi, this may be a stupid question: I am trying to model fire flow using watercad. we had 2 fire flow tests done the same day, each test has one hydrant flowing while measuring the residual from the other one. Each has the data for static, residual and design pressures. Question is: Can I connect the system to both hydrants (pumps) or can I only connect to one at a time?
thank you so much.
thank you so much.
