Gus14
- Mar 21, 2020
- 194
I am learning the design of raft foundations below the water table. I have a couple of questions about the design of the basement slab when the water level is above the basement slab. 1) Should I design the mat for the soil reaction + uplift force? For example, if the mat is sized so that the soil reaction on it is 300 kn/m2 should I add whatever uplift force is ( which let's say might be 20 kn/m2 and design the footing for 320 kn/m2 ) 2) For raft with slab thickened below columns should the slab length be measured between columns or between footings? 3) Should I design for the water table height only or should I design for the full basement height in case the water table rises due to rain in the future?
Sidenote, Question#2 will help me understand the slab design methodology should I model it as an upside-down flat slab supported on columns under the uplift force, or would the footing thickening act as a support? Similar to the following sketch
