drogones12
- Apr 9, 2012
- 30
I have a membrane filtration unit and I need to sample the turbidity on the CFE pipe. I can not sample the water on the CFE pipe because there is not enough water pressure. what can I do to collect the water on the CFE? Is the gravity feed water flow in the vertical pipe a full flow pipe or partially fill pipe? Thank you
