B
bfairhurst
Guest
I have a part that is constant thickness, the shape is a racetrack and both the top and bottom surfaces are curved with the same radius. I have a curve on the top surface and one on the bottom surface that I will use as trajectories for the VSS. After I select both trajectories I cannot seem to get into sketch mode. It has been a while that I have used this command and I am sure a am forgetting someting. I am on wildfire 4. The cut will look like a countersink, where the angle will change going around the radius ends compared with the sides because the offset is different. Can someone point me in the right direction? Thanks. I have attached 2 pics.
