T
TDPROE
Guest
Hey everyone, this is the deal, i need to place a force on a cylindrical pin, at first it would seen easy but the force is not applied on the outer planar faces but on an internal plane 1.875 mm from the edge, im trying to create a volume region but i cant select the face i want, how can you select the other "faces" of the volume region?
thanks
thanks
