If you have added the feature and there are not dependents you can measure the volume of the entire part, then supress the hollow section and remeasure. The difference is the volume youmeasured before.
Sir I dint find any option like SURPRESS hallow section.. please enlighten me on this
Yes you are correct I need volume of the whole part, I did as you instructed, I also got values when I preview button (spectacles button) but the thing is when I try to highlight the object. there no response. so I doubt that some other volume is also included in those values
s_pme20 said:
I think he need the volume of whole part,
Go to analysis>model>mass properties>preview..
it will show volume.
NoTE: for correct mass, u need to apply appropriate material to the part.
