Visual result problem 1
NEROOO
36
Hi there,
my simulation result of crack shows with exaggerate element, as shown in the image:
already click the element deletion, STATUS.
Any suggestions to it?
Need your help!
Thanks a lot!
So you requested output of STATUS variable but is it selected in Result —> Field Output —> Status Variable —> Use status variable ? If yes, check the damage state of these elements. Which damage criterion do you use ?
thanks for the reply! I used ductile damage criteria
I selected Result —> Field Output —> Status Variable —> Use status, remain the same problem
Plot DUCTCRT and STATUS variables for these elements:
- DUCTCRT - a value of 1 means that damage initiation criterion has been met
- STATUS - a value of 0 means that the element is inactive
Also check what happens to these (and surrounding) elements during analysis, as fracture progresses.
Thank you @FEA way, problem solved!
