visual basic string array problem
multicaduser
Industrial
I have a visual basic program that takes the file name and assigns it to an existing part attribute. This works well until the name gets long.
The error that pops up is
"System.Exception: Length of String array does not match with length provided."
First the attribute is read then if the option is chosen the file name is used to replace the attribute or something can be entered manually. This is the line of code it fails on.
usrAttr(2,2) = fnameAsDesc
Nothing unusual and it works well with most file names. My programming skills are not great and any hint on what to try would be appreciated.
NX 12.0.1.7 Windows 10
I assume that "usrAttr()" is a string array that you have created, how is it declared? How long is the name of the file? You might need to post more of your code for better feedback.
www.nxjournaling.com
Morning cowski, thank you for your reply.
Here is how the attribute is retrieved from the existing file.
Function getUsrAttr
Dim theSession As Session = Session.GetSession()
Dim workPart As Part = theSession.Parts.Work
Dim lw As ListingWindow = theSession.ListingWindow
Dim stpr As Integer
For stpr = 1 to 6
If workPart.HasUserAttribute(usrAttr(stpr,1), NXObject.AttributeType.String, -1) Then
Dim attrString As NXObject.AttributeInformation = workPart.GetUserAttribute(usrAttr(stpr,1), NXObject.AttributeType.Any, -1)
usrAttr(stpr,2) = attrString.StringValue
lw.writeline(usrAttr(stpr,1))
lw.writeline(usrAttr(stpr,2))
End If
Next
Return usrAttr
End function
And here is how the file name string is obtained.
fnameAsDesc = (IO.Path.GetFileNameWithoutExtension(workPart.FullPath)).Replace("_", " ")
Dim fnameLen As Integer = fnameAsDesc.Length
fnameAsDesc = fnameAsDesc.Substring(5,fnameLen-5)
This all works fine for most file names, however length and characters such as hyphens or a lot of underscores seem to mess it up. I use a lot of manual debugging such as writing the variable to screen at different points to check if there is something unusual with it but nothing other than a plain text string shows. Just stumped.
The code that you provided is helpful, but it doesn't show how the "usrAttr" variable is declared. Based on the text of the error message, it seems that the array was declared with fewer elements than you intended (i.e. the array doesn't have an element 2,2 - but you try to use it anyway).
Here's the program, a lot of junk in it for trying to figure out the problem. Thanks for your help.
Code:
Option Strict Off
Imports System
Imports System.Collections.Generic
Imports NXOpen
Imports NXOpen.UF
Imports NXOpenUI
Module NXJournal
    Dim ufs As UFSession = UFSession.GetUFSession()
    Dim shtAttrString As String = ""
    Dim dscAttrString As String = ""
    Dim sizAttrString As String = ""
    Dim venAttrString As String = ""
    Dim pnmAttrString As String = ""
    Dim fnameAsDesc As String = ""
	Dim afnameAsDesc As String = "" 'existing description attribute
    Dim usrAttr (6,2) As String
    Sub Main ()
        Dim theUfSession As UFSession = UFSession.GetUFSession()
        Dim displayPart As Part = theSession.Parts.Display
        Dim currentPath As String = IO.Path.GetDirectoryName(workPart.FullPath)
        Dim currentFile As String = IO.Path.GetFileNameWithoutExtension(workPart.FullPath)
setUsrAttr 'set default attribute names and values
getUsrAttr 'get part attributes if exists
If usrAttr(6,2) = "true" Then
   lw.WriteLine("BOM Lock Is Set")
   Exit Sub
End If
'get file name and replace underscores with spaces
'choice menu
   Dim menuChoice As String = ""
   Do
      menuChoice = opChoice
      If menuChoice = usrAttr(1,1) Then inputSheet
      If menuChoice = usrAttr(2,1) Then inputDescription
      If menuChoice = usrAttr(3,1) Then inputSize
      If menuChoice = usrAttr(4,1) Then inputVendor
      If menuChoice = usrAttr(5,1) Then inputMaterial
   Loop Until menuChoice = "done"
   Dim lstpr As Integer
   For lstpr = 1 to 5
      workPart.SetUserAttribute(usrAttr(lstpr,1), -1, usrAttr(lstpr,2), Update.Option.Now)
   Next
   End Sub
    Function opChoice() As String
        Dim opList As New List(Of String)
        opList.Add(usrAttr(1,1) & " : " & usrAttr(1,2))
        opList.Add(usrAttr(2,1) & " : " & usrAttr(2,2))
        opList.Add(usrAttr(3,1) & " : " & usrAttr(3,2))
        opList.Add(usrAttr(4,1) & " : " & usrAttr(4,2))
        opList.Add(usrAttr(5,1) & " : " & usrAttr(5,2))
        opList.Add("Done")
        Dim retVal As Integer = 0
        Dim title As String = "Select file output type"
        theUfSession.Ui.LockUgAccess(NXOpen.UF.UFConstants.UF_UI_FROM_CUSTOM)
        retVal = theUFSession.Ui.DisplayMenu(title, 1, opList.ToArray, opList.Count)
        theUFSession.Ui.UnlockUgAccess(NXOpen.UF.UFConstants.UF_UI_FROM_CUSTOM)
        '1=back
        '2=cancel
        '5-18=menu item selected
        '19=disallowed state, unable to bring up dialog
        Select Case retVal
            Case Is = 5
                Return usrAttr(1,1)
            Case Is = 6
                Return usrAttr(2,1)
            Case Is = 7
                Return usrAttr(3,1)
            Case Is = 8
                Return usrAttr(4,1)
            Case Is = 9
                Return usrAttr(5,1)
            Case Is = 10
                Return "done"
        End Select
    End Function
   Function inputSheet() As String
      Dim answer As String = usrAttr(1,2)
      Dim myInt As Integer
        Do
            answer = NXInputBox.GetInputString("Enter Sheet Number", "Enter Sheet Number", usrAttr(1,2))
        Loop Until Integer.TryParse(answer, myInt)
        usrAttr(1,2) = myInt.ToString(0)
      return answer
    End Function
   Function inputDescription() As String
        Dim dsList As New List(Of String)
        dsList.Add("Use File Name : " ) '& fnameAsDesc)
        dsList.Add("Enter Text")
        dsList.Add("Done")
        retVal = theUFSession.Ui.DisplayMenu(title, 1, dsList.ToArray, dsList.Count)
        Select Case retVal
            Case Is = 5
			    lw.writeline (fnameAsDesc.toupper())
				fnameAsDesc = fnameAsDesc.ToUpper()
                Return usrAttr(2,2)
            Case Is = 6
                Dim answer As String = ""
                Do
                   answer = NXInputBox.GetInputString("Enter Description","Enter Description",usrAttr(2,2))
                Loop Until answer.Trim.Length > 0
                usrAttr(2,2) = answer.ToUpper()
                Return usrAttr(2,2)
            Case Is = 7
                usrAttr(2,2) = usrAttr(2,2).ToUpper()
                Return usrAttr(2,2)
        End Select
   End Function
   Function inputSize() As String
        Dim szList As New List(Of String)
        szList.Add("Pick Body")
        szList.Add("Enter Size")
        szList.Add("Done")
        Dim title As String = usrAttr(3,1) & "  " & usrAttr(3,2)
        retVal = theUFSession.Ui.DisplayMenu(title, 1, szList.ToArray, szList.Count)
        Select Case retVal
             Case Is = 5
                Dim answer As String = sizAttrString
                Dim s As Session = Session.GetSession()
                Dim a_body As NXOpen.Tag = NXOpen.Tag.Null
                Dim csys As NXOpen.Tag = NXOpen.Tag.Null
                Dim target As NXOpen.Tag = NXOpen.Tag.Null
                Dim blockFeature As NXOpen.Tag = NXOpen.Tag.Null
                Dim min_corner(2) As Double
                Dim directions(2, 2) As Double
                Dim distances(2) As Double
                Dim edge_len(2) As String
                While select_a_body(a_body) = Selection.Response.Ok
                   ufs.Csys.AskWcs(csys)
                   ufs.Modl.AskBoundingBoxExact(a_Body, csys, min_corner, directions, distances)
                   usrAttr(3,2) = (distances(0).ToString("f4") & " x " & distances(1).ToString("f4") & " x " & distances(2).ToString("f4"))
                   Return usrAttr(3,2)
               End While
            Case Is = 6
               Dim Answer As String = usrAttr(3,2)
               Do
                  answer = NXInputBox.GetInputString("Enter Size","Enter Size",usrAttr(3,2))
               usrAttr(3,2) = answer.ToUpper()
               Return usrAttr(3,2)
            Case Is = 7
                usrAttr(3,2) = usrAttr(3,2).ToUpper
                Return usrAttr(3,2)
        End Select
   End Function
   Function inputVendor() As String
        Do
            answer = NXInputBox.GetInputString("Enter Vendor", "Enter Vendor", usrAttr(4,2))
        usrAttr(4,2) = answer.ToUpper()
        Return usrAttr(4,2)
   End Function
   Function inputMaterial() As String
        Do
            answer = NXInputBox.GetInputString("Enter Part Number/Material", "Enter Part Number/Material", usrAttr(5,2))
        usrAttr(5,2) = answer.ToUpper()
        Return usrAttr(5,2)
   End Function
    Function select_a_body(ByRef a_body As NXOpen.Tag) As Selection.Response
        Dim message As String = "Select a body"
        Dim title As String = "Select a body"
        Dim scope As Integer = UFConstants.UF_UI_SEL_SCOPE_ANY_IN_ASSEMBLY
        Dim response As Integer
        Dim view As NXOpen.Tag
        Dim cursor(2) As Double
        Dim ip As UFUi.SelInitFnT = AddressOf body_init_proc
        ufs.Ui.LockUgAccess(UFConstants.UF_UI_FROM_CUSTOM)
        Try
            ufs.Ui.SelectWithSingleDialog(message, title, scope, ip, _
                         Nothing, response, a_body, cursor, view)
        Finally
            ufs.Ui.UnlockUgAccess(UFConstants.UF_UI_FROM_CUSTOM)
        End Try
        If response <> UFConstants.UF_UI_OBJECT_SELECTED And _
           response <> UFConstants.UF_UI_OBJECT_SELECTED_BY_NAME Then
            Return Selection.Response.Cancel
        Else
            ufs.Disp.SetHighlight(a_body, 0)
            Return Selection.Response.Ok
        End If
    End Function
    Function body_init_proc(ByVal select_ As IntPtr, _
                           ByVal userdata As IntPtr) As Integer
        Dim num_triples As Integer = 1
        Dim mask_triples(0) As UFUi.Mask
        mask_triples(0).object_type = UFConstants.UF_solid_type
        mask_triples(0).object_subtype = UFConstants.UF_solid_body_subtype
        mask_triples(0).solid_type = UFConstants.UF_UI_SEL_FEATURE_BODY
        ufs.Ui.SetSelMask(select_, _
                           UFUi.SelMaskAction.SelMaskClearAndEnableSpecific, _
                           num_triples, mask_triples)
        Return UFConstants.UF_UI_SEL_SUCCESS
    End Function
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        GetUnloadOption = UFConstants.UF_UNLOAD_IMMEDIATELY
    End Function
    Function setUsrAttr
       usrAttr(1,1) = "sheet"
       usrAttr(1,2) = "1"
       usrAttr(2,1) = "description"
       usrAttr(2,2) = "now this is going to be a very long file name"
       usrAttr(3,1) = "size"
       usrAttr(3,2) = "0 x 0 x 0"
       usrAttr(4,1) = "vendor"
       usrAttr(4,2) = "NA"
       usrAttr(5,1) = "part_num"
       usrAttr(5,2) = "-"
       usrAttr(6,1) = "input_bom_lock"
       usrAttr(6,2) = "false"
       Return usrAttr
    End Function
    Function getUsrAttr
        Dim stpr As Integer
        For stpr = 1 to 6
        End If
        Next
        Return usrAttr
    End function
End Module
Wow, never would have thought of that but should have, grip has the same limitations. Thank you very much.
