View Type Throigh API
  • Thread starter Thread starter NirVid
  • Start date Start date
N
NirVid
Guest
Is there any way, using API, to identify the view type (General / Projected etc.). The View2D object does not seem to provide a way to do this.
May be there is some work-round.
In general, how can you access the information that is displayed when you click on a view and click Drawing View (Viewinfo.inf)
ProDrawingViewType get will get you the data you want.
#include <ProDrawingView.h>
ProError
ProDrawingViewTypeGet
ProDrawing drawing
/* (In)
Drawing handle
ProView view
/* (In)
The view handle
ProViewType* type
/* (Out)
view type (General, projection, detailed, auxiliary, revolved, copy and align, of flat ply)
Thank you williaps for the explanation.
But I am unable to find anything equivalent in JLink / VB.
Is the ProView object available only in ProToolKit and not in JLink / VB?
Hi Patrick,am a bit concerned about the header file you
have mentioned - #include <ProDrawingView.h>
Not able to find it in my machine at -
..\proeWildfire 4.0\protoolkit\includes
Currently am using Proe Wildfire 4.0 and Visual Studio
2005 for Pro/Toolkit.
Am using the code in the below format -
ProDrawingViewTypeGet(drawing, views[view], &viewtype)
But since it is unable to find the above mentioned header
file,it is throwingup the below error -
"SyncrhonousApplication.cpp(59) : error C3861:
'ProViewTypeGet': identifier not found"
Kindly help.
Thanks heaps!
ProDrawingViewTypeGet() is introduced in WF 5.0 , so will not be available in WF 4.0.
Ah thanx..dat helps..i doubted it!:)
Sorry about that. I should have specified the version from which I got the documentation.
Nevertheless,thanks williaps for the clue!:)
