Video Memory or CPU Speed?
  • Thread starter Thread starter kurlee daddee
  • Start date Start date
K
kurlee daddee
Guest
What is more important for running large assemblies and parts with lots of features. A machine with super fast CPU's like Dual Core Intels, or a machine with a lot of video memory? Obviously a combination of both would be ideal, but I am not rich and can't afford a $5k computer.
I still have a post running in the hardware section about buying a Mac and running Solidworks. It will work with Bootcamp with no problems. But, I am trying to decide on whether I should buy a machine with the fastest processors available (two3.0Ghz Dual Core Intels) or a video card with 512mb or more video memory. I am also buying this machine with 2GB worth of RAM.
I have been working with some folks at SEMA. Their large assemblies consist of full vehicles, i.e. trucks, cars, etc. 4gb of ram plus 1gb video and a fast cpu seems to do the trick, well, it's never really fast enough. I am currently running 4gb ram, with a 512mb video, it's a bit slower but efficient.
I just went through this exercise. The information I have indicates that CPU speed is somewhat more important than video card performance - IF your video card is adequate to run SW. But the video card is a close second.
I'd order it as:
- Get a good, solid, SW-approved video card.
- Get as much RAM as you can (At least 4 Gb - RAM is cheap)
- Get as much single/dual-core CPU as you can justify. Don't get a quad-core.
- Get the fastest hard drive you can justify
In each case there will be a pricing breakpoint that will prevent you from going any bigger/faster on your budget.
These links may help you decide bang for the buck:
[url]http://www.solidworks.com/pages/services/Tech_Tips/TT_Choose System.html[/url]
http://www.nvidia.com/object/IO_11761.html
[url]http://www.tomshardware.com/charts/workstation-graphics-card s-charts/specapc-solidworks-2007-cpu,125.html [/url]
[url]http://www.tomshardware.com/reviews/workstation-shootout,172 1-8.html[/url]
[url]http://designsmarter.typepad.com/devonsowell/2008/04/solidwo rks-perf.html[/url]
Sean is right, SolidWorks uses the CPU way more than the
vid card. And since SW is a single threaded process
software, so a quad core isn't necessary, but if you want
to do anything else in the background, it's a good idea
to have more rather than less.
As for running SW on a Mac, it's just not economical. You
can get a bada$$ PC set up for way cheaper, and it will
probably outperform the Mac just because the software is
designed for a Windows environment. Maybe I'm oldschool
and that's changing, but it's not like Photoshop or any
other program that has a background in Mac language.
If you can, invest in a Solidstate hard drive for your
primary drive, and run a raid 0 on two mechanical drives
for everything else.
