very beginner with Motion
  • Thread starter Thread starter Juju
  • Start date Start date
J
Juju
Guest
Hi, I am looking for very basic exercises in order to start learning Pro Motion. Is it possible to find a few documents on the Internet ?
Edited by: Juju
Hello Juju,
Below are some introductory materials for ProMechanica Motion:
Sample chapters from Schroff publishing:
http://www.schroff.com/scstore/pdfsample/1-58503-191-7-1.pdf
University of Victoria:
http://www.me.uvic.ca/~mech410/Tut2001/ProMMotion.pdf
However, I would not recommend studying this module as PTC is about to retire Motion soon:
http://www.ptc.com/carezone/archive/newsletters/103105_a.pdf
Functions are integrated in Wildfire 2.0 ProMechanism module. But you need a license to run MDX and an extension license for Mechanism Dynamics(MDO).
Here are some tutorials for your reference:
http://www.staffs.ac.uk/~entdgc/WildfireDocs/tutorials.htm
Hope this helps and good luck!
You probably would be more interested in Pro/Mechanism MDO than Pro/Mechanica Motion. The latter was discontinued and replaced with MDO.
Hi, sorry I haven t understood your answer Natewebb, can you explain it again please.
I also found 3 tutorials for Pro Mechanica Motion in the help provided with the software, it seems quite interesting.
Thanks Fire-dragon, the document "Pro/Mechanica Motion : Mechanism Design and Analysis" seems really interesting, is it possible to find more chapters ?
Hi Juju,
I'm not sure if the other chapters are available. These are actually sample chapters from the book.
Anyway, it would be an advantage to understand the principles behindmechanismdesign and analysisfirst. Then you can move on to studying the rest using the help.You can also "experiment" and just useyour curiousity to learn more about the module.
OK, i am trying to learn a bit about that by using the help. I will bea good beginning. thanks
S.O.S
anybody show me the ways to install promechanica in proengineer wildfire.
thanks ,
Can anybody share with me the 3 tutorials on MDX/MDO which is being referred here? I too am a beginner in Motion and your help would be highly appreciated.
Deepak.
