VBA code to insert the customized symbol in catia drawing which can be replaced using excel file 2
Ajaypatil8458
Aerospace
May 15, 2020
12
I have saved some views as a symbol which I am currently in inserting into the CATIA drawing using Catalog option. I need to change these symbols with the input provided in design table excel sheet.
Is there any way to do this with VBA code or for that matter with parametric modelling?
Any help related to this is greatly appreciated.
Vijay
I am using CATIA V5-6R2017
It should fine then.
Get in touch with your IT department to verify CATIA is installed properly.
Following script should always work:
[script]Option Explicit
Sub CATMain()
MsgBox CStr(CATIA.Documents.Count)
End Sub[/script]
Yes below code is working but not the other one which you have posted.
Code:
Option Explicit
Sub CATMain()
End Sub
Any suggestions.
Regards...Vijay
Hi Again,
i have below code where I can replace the 2D component but seleciton of 2D component is manual, any idea how I can do that using 2D component name.
Code:
'---- Begin resolution script for object : 2D Component.1 (Instance)
Set drawingDocument1 = CATIA.ActiveDocument
Set drawingSheets1 = drawingDocument1.Sheets
Set drawingSheet1 = drawingSheets1.Item("Sheet.1")
Set drawingViews1 = drawingSheet1.Views
Set drawingView1 = drawingViews1.Item("Main View")
Set drawingComponents1 = drawingView1.Components
'Set drawingComponent1 = drawingComponents1.Item("2D Component.1 (Instance)")
'---- End resolution script
Dim compsel 'As Selection
Set compsel = drawingDocument1.selection
compsel.Clear
Dim ocomp(0) 'As String
    ocomp(0) = "DrawingComponent"
    Dim Staus
    Status = compsel.SelectElement2(ocomp, "Select 2D-Instance to Replace reference", False)
    If Status = "Cancel" Then
        Exit Sub
    End If
Set drawingComponent1 = compsel.Item(1).Value
compsel.Clear
ocomp(0) = "DrawingView"
Status = compsel.SelectElement2(ocomp, "Select NEW 2D Component View", False)
       Exit Sub
    End If
Set drawingView1 = compsel.Item(1).Value
compsel.Clear
compsel.Add drawingComponent1
CATIA.StartCommand "Replace Reference"
'compsel.Clear
'compsel.Add drawingSheets1.Item(2).Views.Item(4)
'compsel.Add drawingView1
Also instead of replace how I can insert the 2D component from catalog using Macro.
Thank you.
regards...Vijay
