W
warmwinds
Guest
I want to build a spring using a helical sweepandset the pitch as a variable, defined as a parameter. When I set the pitch it will accept a parameter but it simply sets a numerical value based on the current value of the parmeter. If the parameter is changed, the pitch will not change. Does anyone have any ideas?
