R
roldy
Guest
I have a model with 2 solid bodies. Below is the structure of my file.
1st. configuration contains union of the of 2 solid bodies
2nd. configuration contains Body 2
3rd. configuration contains Body 1
I want to be able to find the volume in each configuration and use these values in a drawing showing each configuration. I've tried assigning a variable for each configuration for the volume but the values keep changing.
What is the correct way of doing this?
