R
rpiatt
Guest
I'm having trouble using the filter with a parameter together. Below is an earlier post from another user that was trying to call out sub-asm's. I am trying to call out info from a family table, and not an assembly. The code they used didn't work for me(&asm.mbr.SUB_ASM == "S01"). Is there something different I have to use? Any help would be appreciated. Thanks.
"Hi,
I have the same situation and i had overcome it by simply adding additional parameter in the parts. Say for example,
for Part_1:
parameter: SUB_ASM and its value S01 (for sub-assly 01)
for Part_2:
for Part_11:
parameter: SUB_ASM and its value S02 (for sub-assly 02)
for Part_12:
so on till all the parts.....Yes! you have to do like this for all the parts, if u wanna have ur output as u wish. (these things should be carefully thought before doing the design)
now you apply your logic in filters->by rule
or
&asm.mbr.SUB_ASM != "S02"
or
&asm.mbr.SUB_ASM != "S01"
or
&asm.mbr.SUB_ASM == "S02"
as per ur need and update the bom. u will get it. hope this wud b helpful.
-Nawaz"
"Hi,
for Part_1:
for Part_2:
for Part_11:
for Part_12:
or
or
or
-Nawaz"
