Using Ghostscript for converting .plt
  • Thread starter Thread starter C.Andersson
  • Start date Start date
C
C.Andersson
Guest
Hello everyone. One of these classic problems.
I use the regular "printthe active object"-button in WF3 and then select my own .pcf-file to make a .plt-file that will convert to .pdf through a .bat-file that startsGhostscript 8.6.
But Ghostscript doesn
You are deleting %outname% with the last line of your batch file.
Try move %outname% C:\"your_pdf_folder"
How do u mean? Just edit my .bat-file please :)
Edit your batch file.
Change line:
del %OUTNAME%
To:
move %OUTNAME% C:\"your_pdf_folder"
Where "your_pdf_folder" is the location path for your pdf files
e.g.
c:\proe\pdffiles
Change line:
del %OUTNAME%
To:
e.g.
c:\proe\pdffiles
The .pdf is coming, but now i would like it to get sent to a printer. Anyone know how to do that?
Try to copy to your printer network nameinstead of ip.
I just tried my installation and replaced the printername with ip and then it didnt work anymore....
