P
ptcmatt
Guest
I have been trying for a while on this issue but would like to see if you have any suggestions on best practice etc.
When we create new drawings we want the user parameters &description and &drawing_no and the system parameter &proi_revision to be read from the drawing file, not the model. I can get this to work for the user parameters with :d at the end of the parameter but the &proi_revision does not work. It removes the & sign and when you have saved the drawing and checked it in to Commonspace (to get the revision), opening the drawing the parameter is not working. Any suggestions on how to solve this ?
Many thanks,
Matt
Many thanks,
Matt
