D
dinneth
Guest
Hi
I am a new member and have a problem with printer. I searched our forum and did not find good answer. I am not sure whether or not it is correct to place printer question here (CAD Administration). If it is not proper, I am sorry. Please move this topic to the forum where it should be.
Pro/E WF 2.0 M171
WinXP SP2
Network printer HP LaserJet 5000 LE
In order to print .drw drawing in Pro/E, I create a .pcf file.
button_name HP_LaserJet_A3
button_help Plot from HP LaserJet
plotter LaserJet5000LE
plot_drawing_format yes
allow_file_naming no
paper_size A3
plot_translate -0 -0 mm
plot_access create
delete_after_plotting yes
plotter_command windows_print_manager \\ServerName\PrinterName
pen_table_file C:\Proe_wildfire2\Standards\Plot_Configs\Pen.pnt
plot_with_panzoom no default
But when I open a drw file, Menu -> Print, in the pull-down list near the field of Destination, I cannot find the printer. As I imaged, there should be an "HP_LaserJet_A3". I asked a friend, he said, only the printers what Pro/E "know" will be show here IF I use real printer type name in the "plotter" option in .pcf file. If Pro/E does not know my printer, I have to use postscript in the "plotter" option in .pcf file.
Is it right?
And if I use postscript, my printer print some strange code instead of my drawing. Then I call HP support hotline. They told me that HP LaserJet 5000 LE does not support postscript. Oh ...
Could anybody please give me some suggestion?
Thank you!
Yours
Dinneth
Pro/E WF 2.0 M171
WinXP SP2
paper_size A3
plot_access create
Is it right?
Thank you!
Yours
Dinneth
