Has anyone thought about using steel rebar on the inside of a concrete basement block wall to reinforce it and prevent further bowing and cracking?
What I am suggesting is cutting vertical v-shaped grooves in the inside face of the block wall, floor to ceiling at regular intervals maybe every 2 1/2 to 3 feet. Each groove would be wide and deep enough to accommodate a #4 or #5 length of steel rebar. The rebar would be bedded in a continuous bead of epoxy or other suitable adhesive and would be flush with the inside surface of the block.
If feasible, this method would provide a number of benefits:
-Significantly lower cost than using carbon fiber straps
-It would serve to lock the courses of block together. This might be very beneficial if there were significant stair-step cracking of mortar joints.
-It would be minimally invasive
-The homeowner could install this system with an angle grinder and a few diamond cutting blades.
-It would require less cutting/grinding than with carbon fiber straps
If additional anchoring were needed, the top of the rebar could be bent and inserted into a hole drilled into the top block, or is could be attached with some kind of bracket and lag-bolted to the sill or a floor joist. The bottom could be inserted into a hole drilled in the floor slab.
What are your thoughts on this idea?
Frank W.
Frank W.
