Use of Gate Valve for Throttling 6
ASA2025
Hi All,
I would appreciate your insights regarding the temporary use of a gate valve for throttling service. Specifically, I would like to understand:
  1. What potential issues or risks could arise from this mode of operation?
  2. What would be an acceptable duration for operating the valve in this manner?
Technical Details:
  • Valve Size: 24"
  • Valve Trim: SS316
  • Operating Fluid: Cryogenic
Thank you in advance for your support and valuable feedback.
You don't say what pressure drop or flow you're expecting or why this needs to be done?
Issues - low control of flow. Small movements of the gate results in much bigger changes in DP / flow
Depending on the design of the valve ( cross section would help as "Gate valve" can mean many different configurations) you can easily destroy the seat and or gate meaning it wont seal. Not sealing after use is highly likely.
Erosion and or cavitation could lead to destruction of the gate meaning no valve left.
If this is a high DP throttling ( anything more than 1-2 bar) your control function is very poor and damage to the valve very likely.
Valve may fail completely.
"Acceptable" duration for me would be limited to minutes, not hours, but even this could result in damage to the gate and seals.
Overall, this is a poor decision, IMHO, that has significant risks that need to be understood and accepted or mitigated. E.g. you absolutely need a second valve in series which can be relied upon to cease flow when you need to and not rely on this gate valve.
Is that what you wanted to know?
Thanks a million, LittleInch, for your response.
We are evaluating the use of the gate valve to generate backpressure for supporting system equipment rather than for precise flow control.
At this stage, data on the valve’s performance under throttling conditions is limited to what I’ve already shared. You’ve correctly highlighted the principal risk—damage to the gate and its seals, which likely applies across most configurations.
Could you clarify what other failure modes might result from this proposal? Specifically, beyond gate and seal damage, is there a risk of loss of primary containment that could result in a release?
What do you have to lose if the valve fails?
-Does failure pose a safety hazard?
-Does it pose an environmental hazard?
-Is needing to repair or replace the valve an acceptable cost?
-Is the loss of control of the process going to result in loss of valuable product?
-Are there other components in the system that may be damaged by excessive vibration or debris from the valve?
As the wedge will lose contact with the seats under low flow conditions, vibration of the wedge may occur, which may damage the wedge and seats.
And the guides and the stem to disk connection.
Thank you for your response. These are my concerns.
We are open to accepting the possibility of valve failure, so long as it does not compromise the integrity
of the piping system, lead to an environmental release, or pose safety risks to personnel.
I’d like to get your input on a few specific points regarding possible failure modes if a gate valve is used for throttling:
  1. Leak Potential:
    If the gate valve is used in a throttling capacity, is there a significant risk of leakage?
  2. Impact of Vibration:
    Could throttling lead to vibrations that may adversely affect the piping system or its supports?
  3. Operator Safety Risks:
    Are there any other major hazards that could endanger personnel while operating the valve in this mode?
I doubt you would get actual valve body failure but not impossible if you get a lot of vibration.
Difficult to speculate without more details.
Isolation valves ( ball, gate etc) get used all the time as throttle valves when they shouldn't and survive. For me the risks of body failure are very low, with risk of damage to the valve and seals very high. That's about all you can say really at this level of detail.
The primary concern is potential damage to the valve body that could result in a loss of primary containment (LOPC). As a mitigation measure, we may consider implementing vibration monitoring and trending to ensure that any induced vibration remains within acceptable thresholds.
Thank you for sharing your insights.
Well noted. This aligns with one of the failure modes we were particularly interested in understanding further. Your input is valuable and will contribute meaningfully to the assessment we plan to conduct. Thank you for sharing your insights.
Complementing all the comments from experts above, gate valve even though can perform throttling, but it is not advisable to do that.
Premises:
  • Gate valve selection by most Principals is considered as isolation valve (it should be able meaning to isolate downstream/upstream for positive isolation and/or process safety purpose e.g. maintenance purpose on one side of the valve).
    • Therefore, it relies heavily on both seats and wedge sealing area should be in good condition.
  • Throttling at some extend will erode that sealing area,
    • thus expect that it may no longer serve its purpose when needed as ‘positive’ isolation device
  • All structure, including valve has their own natural frequency.
    • Therefore, in the unlikely event, at the right opening of valve; right flow and right piping configuration, yes it possible for vibration induced by vortex shading
    • In the rare event, it is also not impossible for vibration on wedge transferred through the spindle and initiate some sort of gland relaxation. Usually, gland start to sweats.
  • Flow from upstream in full bore condition suddenly ‘hit’ partially open wedge, is susceptible for turbulence before and/or after the wedge
    • In the very rare event (usually in combination with casting defect), turbulence may erode valves body.
  • 99% of gate valve doesn’t have position indicator related to Cv.
    • Thus, operators throttling gate valve by feeling and/or sometimes blindly (just based on whatever control room find sufficient).
To put in context, I may not directly answer your question, but dealing with ±1,5 millions gate valve in my complex refinery:
  • Our operators with and without Principal consent do throttle gate valve, and every week I got notified that some (new) gate valves are passing and caught our operators by surprise.
  • Seen a handful of pinhole incidents on gate valve body due erosion induced by turbulence. However mainly for valves more than 20 years in service.
  • Seen an incident when the whole 2nd floor of platform vibrating when a gate valve used for throttling
Don’t normalize gate valve throttling. It may seems ok at first but will have different repercussions afterwards (within days or even years).
Remember, this is quite a large gate valve so the forces generated are going to be very high.
Since this is a DN600 gate valve, think the shear force generated at the gate stem could be considerable - check what diff press is required, and see if the gate stem could cause some internal damage that may make it inoperable.
We have applications using wedge gate valves for steam/water flow control. (DN350 class 900)
The control loops are very show acting and do not cycle much
Sitting at small valve opening is avoided
Valves bodies have V notch fitted
Valves are not expected to seal
These valves do quite well in this application compared to 1/4 turn valves.
