Uploading using Java
  • Thread starter Thread starter eepgmik
  • Start date Start date
E
eepgmik
Guest
Does anyone know if it's possible to write java code to talk to Intralink? I want to upload some custom data to Intralink.
If so, can you point me in the direction of a manual on it please?
Martin Kemp
we do this using Java and intralinkand wildfire, we do bespoke software, unfortuneatey we have to charge, but it is possible.
Mike
Martin,
A word of warning first. Whatever you try to import to Pro/INTRALINK, do it through the Pro/INTRALINK Client UI. Bypassing the UI could cause database corruption.
Importing non-Pro/E objects can be automated using Pro/INTRALINK Scripting. From the Pro/I Client select [ctrl]+s to access the scripting interface. Pro/I Scripting records key strokes similar to Pro/ENGINEER mapkeys. The picks are recorded in Java so you can easilly expand the default functionality.
Like trail files, PTC only implemented this technology to help replicate software bugs. But I've gotten it to do quite a bit that PTC never thought about doing.
You can write a simple script to loop through a series of folders on the hard drive and import objects. You can even set the attributes for these objects and automatically check them in. Pro/I Scripting supports completely unattended sessions. A script can be called from the Pro/I Client startup command.
As far as I know there isn't a manual for Pro/I Scripting. But if you know how to program in Java, you won't have any problems getting it to do what you want.
Thanks Matt,
I would like to customise an application to perform the upload, rather than do it manually. I'm going to investigate this further now.
Martin Kemp
PS: How's RSDesigner going for you? Are you still using it? (We met at the PTC/User TC meetings in Needham in January).
