Unbending a Louvre
  • Thread starter Thread starter SCUBARENE
  • Start date Start date
S
SCUBARENE
Guest
View attachment 5626Hi Everyone
I need help with a part,I need to bend a Louvre,but when I try to unbend it says "Geometry is not unbendable"
Part was created by sketching and extruding and then converting to Sheetmetal.
I tried adding a flat wall but with same result.
Working in Pro E 5
Any help is appreciated
Thx
-Sorry Picture added
Edited by: SCUBARENE
Dear SCUBARENE,
Could you please upload a pictures of that part (the way you are doing that bending operation) so that we will have a better clarity of your problem.
I always recommend creating sheetmetal parts in sheetmetal module from start.From your picture it's not clear what's the shape behind it..But when you create it fully in sheetmetal, u can surely unbend it.
Compound bends cannot be unbent.
Just because you can make it in sheetmetal does not mean that it can be unbent.
Agreed, I have created many sheet metal parts that won't
un-bend, however the above is also true that you have a
better chance if you can manage to create your part in
sheet metal from the start.
Scubarene:
If you need this in sheet metal, you may want to look at starting with a flat then adding the lourve as a form feature.
Bob
Sheetmetal can only unbend a straight bend operation. A louver is a combination of a bend and stretching by the punch.
If the louvre is formed using a form tool then it can be flattened by using the flatten tool or suppressing the form feature.
Bob
