I’m currently working on customizing Patran 2020 on Windows by creating my own PCL functions and placing them in a dedicated folder. According to the documentation, Patran uses !!PATH to search for PCL files, so I’ve configured it accordingly.
Specifically, I’ve added the following files to the directory:
This directory is listed when I run the !!PATH command inside Patran.
The files in this folder are (attached):
Inside p3epilog.pcl, I load my function file. However, when I launch Patran and try to call the function swap_b_to_w(), I get an error saying the function does not exist.
Strangely, if I copy these three files into the same directory as my .db file, the function works perfectly.
Eventually, I also plan to add a custom menu or toolbar to access my functions easily.
Could you please clarify:
Thank you in advance for your help.
C:\Users\user\msc\patran_2020
- p3epilog.pcl
- swap_bw.pcl
- color_swap.plb
My objective:
I want to be able to keep all my custom PCL code in a single shared folder, independent of where my .db file is located. I would like to avoid duplicating the files across each working directory.Eventually, I also plan to add a custom menu or toolbar to access my functions easily.
- How to properly set up !!PATH so that functions defined in external PCL files are always found?
- Whether !!PATH is only used for certain types of lookups (e.g. !!INPUT) but not for function definitions?
- Any recommended approach to manage reusable PCL libraries?
