Unable to install NX HelpServer.1.0.5 1
Tingsryd
Industrial
Jul 28, 2010
269
I am planning to install series 1926 docs but first I need to install HelpServer.1.0.5. When running the exe it returns the error "Please check you have installed the correct version of java in JAVA_HOME as a SYSTEM variable and that it is available".
I currently have Java version 8 build 261 installed, which is 1.8.0_261-b12 so I believe that is a usable version.
The system variable JAVA_HOME is set to where java is installed, in this case is C:\Program Files\Java.
Any ideas why it is returning an error?
NX 12.0.2
Testing NX 1936
Just a guess:
Try specifying the folder for your exact version of Java. In your case, something like C:\Program Files\Java\jre1.8.0_261-b12 (or whatever the folder name is for your version).
www.nxjournaling.com
You will need the 64bits java version
Gelson Z. Nicoletto
Eng. Supervisor
Mould Desing
Brazil
@ Gelson
I verified I am using the 64 bit version, thank you!
@Cowski
Your full path recommendation did the trick! I wouldn't think that a version folder in a path would be good for software design but oh well. By the way i did not use a back slash on the end of the path.
NX 12.0.2
Testing NX 1936
