ug to proe
  • Thread starter Thread starter jyoung
  • Start date Start date
J
jyoung
Guest
does any one have any suggestions on how to import a native ug file into proe?
You were supposed to be able to import a native UG part into wildfire (solids only no surfaces) but I havent tried it.
I can find no mention of it in support at ptc.com either.
I ended up buying UG to translate surface files so I have never followed up on it.
Mike
Hi jyoung.
We have a constant need to talk to GM (the Biggest UG User). The only succecful sure fire war is to use a STEP translator (AP214 preferred). We have Solidworks with a native UG reader plugin and tried varous third paty plugins ourselves, all were pretty average with the results. The only way to ensure a high level of sucsess is to aks the suplier/customer for step files. Or buy/hire a seat of UG and charge the customer lost of money $$$$.
Skuld:
You are very lucky. We have to send/receive all data to GM in UG format.
No step,igs etc.
How'd you swing that?
Mike
Miked:
We didn't swing it. I had to go and learn how to UG. But there is some good news (at a cost).
First off, there is now way to avoid using Unigraphics (and it's not such a bad product - Your general CAD skills can only improve from the exposure to more CAD sotware).
We still model all our parts in Pro/e and manage the parts data base with Intralink. But when we want to give parts to GM (Astralia and America), we translate the parts with step to UG.
Here comes the important part. In order for GM to be happy the part file must pass the GM TOOLKIT file checker. This basicaly looks for corect layer stuctures and Catagorys (A Catogry is a UG way of grouping layers together). The part file names maust adhere to the GM standards - ie 12345678.mldes.0001.prt is a typical part number and bunch of other technical PDM type stuff. If you only get one seat of UG you wont need to run Iman (the ug equivalent to Intralink). But you will ned to purchase the GM TOOLKIT as well as your seat of UG (it runs sweet on Win2K so you won't need to falk out huge bucks for UNIX hardware).
The best bit is when you read the step file into into UG is that you only need to create a part file (not a whole bunch of messy assemblies and components). This is because GM won't issue part numbers for every thing in your assy, they are only interested in the parts the have the 8 digit GM number.
Talk to your contact at GM for all the details but I it is quite a painless procces to supply UG data to GM that meets their needs.
But as you can see it is more complex than just reading and out putting as UG readable file. The GMtool kit is needed and it needs UG to Run...
Lots of luck and have fun Learnig how to use UG.
regards:
Skuld:
PS: if you want to supply to Ford or Chrysler you can also look forward to learnig how to Use IDEAS and CATIA as well, the Pro/E CATIA readers are just not good enogh to deal with the the full range of CATIA files.
You may want to check out the CIMPro-UG at www.cadcam-e.com. It runs inside Pro/E and can read native UG file.
Kumar
So far we have bought proe , UG, Ideas, mastercam, and rhino to deal with automotive work.
The mastercam was a bad idea but we were sold on the catia tranlsator. Rhino is great for weeding out extra surfs and curves and will opne just about anything,
Ideas sucks.
I am just learning UG and will be taking training over the summer if things slow down.
We have the GM supplier pack but they only use our files for reference so we havent had to worry about perfect translations.
We deal with GM/Saturn, Nissan/Infiniti, Toyota/ Lexus, Chrysler and VW so I am getting lots of experience w different systems.
We only have one seat of UG but I have heard grumbling about us not using IMAN. What is it and is it a big deal to set up?
Mike
Mike, Iman or UG/Manager is the Unigraphics version of Intralink. It's not hard to set up you just need to know a few outside programs like Oracle and/or Java. I don't mean to scare you, because you'd need to know about the same to set up Intralink. Now, having said all this, you don't have to have it to run Unigraphics as you need Intralink to run Pro/E. UG has some enteral code that would allow you to set up revision rules so that when you opened an assembly, the software would search for the latest revision (not version) of the components.
Steve C
The revsion rules would be for their parts or ours?
The biggest problem we have is when platform updates components and they dont notify release engineer who in turn has no idea his parts will no longer fit. So I thought maybe IMAN was some sort of link between their system and ours.
I would never ever want that.
Most times they have no clue what the most current revision level is.
Mike
Well, if you're not using Iman (think of Iman just like you would think of Intralink, just a little more powerful) to interface with your car guys, then the revision rules would mostly be for your company. If, however, you are required to be on Iman so that you will get the latest information about the parts you have described, then the revision rules will not apply. I know that GM can be pretty particular when it comes to CAD standards, so I would think just as long as you saved a part for them in their naming conventions, it would fit into their Iman system.
When you say that 'Most times they have no clue' are you talking about the GM guys have no clue about what revisions your parts are at, or are you saying that GM changes parts and you have no clue that parts have changed?
Steve C
The release engineers dont always know the latest revs and they dont know cad.
The UG guys always know, but you have to constantly ask them to check. Its definitely a union atmosphere.
Mike
