L
lcl
Guest
Hi.
I wonder if I can create an UDF associated with something such as a family table?
I mean, if I have an UDF for make holes screw holes and the UDF is composed by a revolve feature with the drill hole for thread, drill hole for thru hole and the c'bore for screw head; and a cosmetic thread. Then I want to be able to chose, as example, the screw I'll use on this hole will be a M6, and all the feature (drill for thread, thru hole, c'bore and cosmetic thread diameters) update alone.
